Engine and Tranny Technical Archives - Toyota at Off-Road.com
May 12, 2008
Superchips wants to know: What is the main reason you would purchase a new tuner?
Performance gains
28%
Torque gains
10%
Fuel mileage gains
37%
Powertrain Warranty
1%
Optimize your vehicles performance
25%
View Results
Price and Compare Vehicles:
New | Used | Powersports Go button
  • Project ORT Cold Air Intake Install
    The Toyota pickup is known for being a vehicle that will last a long time without any major mechanical problems. The small 22RE 4 cylinder motor also being known to run for a very long time. But, this motor definitely does not exude power
    FRAM Boost Performance Air Intake System
    FRAM has recently launched a cold air intake system for Trucks and SUV's called the FRAM Boost Performance Intake System. After learning about this new product, we had to take a closer look.
    Toyota 4Runner Modification Information
    Unless you really want to pull things with your 4Runner, most of the drivetrain can be kept stock. Other things, though, tend to be weaker. Here are some reccomendations:
    Project Tacoma: High Clearance Transfer Case Mount
    Front Range Off-Road Fabrication, of Red Feather Colorado, is a company known for making Toyota truck products that address shortcomings of factory components. Their products are designed to fill voids existing in the aftermarket and help Toyota owners to build their stock vehicles into capable trail-rigs. Some of their 4x4 Tacoma specific products include twin-stick t-case shifters, U-bolt flip kits, full floating rear axle conversions and fabricated sheet-metal axle housings.
    Project Tacoma: K&N Fuel Injection Performance Kit
    K&N Engineering offers a FIPK (Fuel Injection Performance Kit) for the 2.7L 4-cylinder engine in the Trails Less
